Thanks to the dedicated work of a few Raptor forum members it finally appears to be safe to buy the Vapor now and expect the tach to work reliably...
Thanks guys.
The short story is; Get the new Tach lead with resistor in-line from Trailtech.net and install it as described below.
As for the erratic tach reading, here is what you have to do and a few pictures also. You will disconnect the white connector from the coil and the you will need to bear the wire and then just install it into the white connector, and then ground underneath the reg/rec.
Good Luck!
Thanks guys.
Good Luck!
