Anyone have a wiring diagram for a 2003 660 Raptor? I bought a bike with a bunch of stuff eliminated and I want to know what the connections go to before I cut them and I want to see what connector goes to the temp light because I am going to put it back on.
The manual floating around the web is for the 01, YFM660RN
the 02 is a 660RP, the 03 is a 660RR, There may be changes in the different years. Like wire colors.
The temp light has a Red/Black and a White/Blue.
Switch is feed from a thermal switch with a White/Blue and a Black.
Gotcha... does an 05 manual exist in pdf? BTW i have an 05 so if you need to know which connector goes where, i'll help... which side of the temp light sensoer did you cut? on the dash mount or down by the tank?
__________________
05 660r<br /> Houser +2, Elkas, Pro-Design, CT Racing, Tusk, AC Propeg, Motion-Pro<br /><br />06 2500 CTD Ram Auto on Rockstars and Nitto TGs, faster than Samrambo's cars.
Deception, do me a favor, look at wiring diagram towards the end on the manual and compare the wire colors I posted to whats in your book.
i have the web manual... i physically looked at my quad, temp light is red/black and white/blue. When you say switch, do you mean where you put the key? Mine is one red and one brown.
my manual says the switch should be red and brown.
__________________
