» Site Navigation |
» Buyers Guides |
» Links |
07-01-2009, 04:17 PM
#11
Lifetime VIP
Followed all these instructions last night and done this mod to my 06 raptor 700 worked great and love the new speeds.. thanks for posting this step by step informations.. good job
__________________
2007 Yamaha Raptor 700 Black & Orange--flex bars w/billet bar clamp, 6 pack rack, nerf bars, looney tuned dual exhaust, dobeck programmer, open airbox large throat w/k&n, speed mod, cam, ported and polished... much more...
| Sponsored Links |
Advertisement
10-12-2009, 01:16 PM
#12
The Portuguese
Can anyone please post a pic or point to me the plug that I can unplug to try out if I should or shouldn't do this mod?
10-12-2009, 03:28 PM
#13
VIP
Best way to get rid of speed limiter is to buy a dynotech ignition. I bought mine from DL700. He put in a custom curve for my mods and one for my future mods dude knows his stuff to.
10-12-2009, 03:58 PM
#14
Senior Member
i made it ten minutes on the highway before my check engine light came on when i unpluged my sensor... get the ignition or ground the wire
__________________
08 raptor 700r
hmf pro carbon fiber full exhaust
pro design intake
dobie tech fuel controler
stage 2 hot cam
735cc big bore kit
12.5comp piston
armmadillo full engine skid plate
armmadillo a-arm skid plates
tusk front bumper
tusk nerf bars
tusk heel gaurds
msr high rise handle bars
pro taper grips
duro burm raider tires
10-12-2009, 07:23 PM
#15
Member
hi guys
i have the 09 700R and did the steps as above where i grounded the wire and have had no problems at all went from 125km to 134km did to a mates 09 700r same as mine no probs at all
but we did do it to another mates 07 700r and the bike would not start the only problem was when pushing the plug back in the black wire didn't reseat and pushed the wire out after we finally found this problem after about 3 hrs and a cpl beers we reseated the black wire and have had no problems with his bike as well
10-20-2009, 11:18 AM
#16
Junior Member
quiestion!! if conect this cable baby blue, with a switch to ground, whith out umplug from de ecu, when I need most speed. obtain the same result
thank you!
10-20-2009, 11:46 AM
#17
Senior Member
Quote:
thank you!
There is no reason for a switch. Just disconnect the battery and ecu, ground the baby blue wire on the corner of the harness and call it a day. If you unplug the sensor on some bikes the rev limiter will still pull timing and there is no point and on some it works but the check engine light comes on and then run like crap. If you ground the wire the light will not come on and it will guaranteed remove the speed limiter. There are people on this forum that have ran this mod for years with no issues.
10-20-2009, 12:03 PM
#18
If it's too loud your too old
Quote:
+1 I've had it done on mine for over a year and no problem at all works great! Gained almost 6 MPH on GPS and my Vapor.
__________________
  "07" Raptor 700R- Sparks XX6, Veloscity filter w/Custom Intake,MSD fuel controller, Custom Axis front shocks,Ohlins Rear,Tusk nerfs, Custom A arm guards,PRM skids,PRM bumper,Hiper tech3 wheels orange rings,22x11-10 Maxxis Sur Tracs Rear,23x7-10 Goodyear Tracker PT front tires,Pro tech air box lid,ATV Fourplay Soft bars,Dr.D Reverse lever,+4" SLC swinger,Vapor,Maier carbon body,Custom +2 1/2" stem +2" ASR A-Arms,Xcaliber Axle,+3TB,TRF 565 pink Inj.,106mm cylinder,12.5:1 JE,HDD5050,Dynatek Ign
10-20-2009, 12:51 PM
#19
Senior Member
Here is a link to the past speed limiter removal topic also if anyone wants to read it. After a few pages people talk about what gains they have achieved from this mod.
http://www.raptorforum.com/forums/sh...ad.php?t=48767
10-20-2009, 07:34 PM
#20
Member
Does this only benifit you in 5th gear??
I heard someone else talking about it retarding the timing etc.
I just want to make sure it is only in 5th. If so I am not too concerned because Im scaaaaarrrrrreeedd  to go to fast on the top end so it really isnt an issue for me.
I like to get to my speeds in a hurry, but I have no biz going 75mph plus offroad if I am not in a roll cage  .
I know I am a sissy
Thanks
Robert <><
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
