How do I adjust the Clutch Cable? - Raptor Forums: Yamaha Raptor Forums
» Sponsors
Go Back   Raptor Forums: Yamaha Raptor Forums > Raptor 660 Categories > Raptor 660 Maintenance
Reply
Thread Tools Display Modes
Old 09-11-2010, 10:01 PM   #1
mollmanhj
Junior Member
mollmanhj's Avatar
Default How do I adjust the Clutch Cable?
I have a problem with my clutch. When I first startup my Raptor and put it in to 1st gear it jumps forward. It happens with the cluch still in. How do I adjust the clutch cable?
__________________
2005 Yamaha Raptor 660R
-Renthal bars
-K&N Filter
-Jetted by Alba Motorsports
-Alba full pipe with muffler
-Alba nerf bars
-ASV clutch lever
-Aftermarket fuel cap with stubby vented hose
-Wide rear aluminum grab bar with quick disconnect whip mount
-Custom front bumper
-Custom aluminum rear skid plate
-ITP front and rear holeshots tires on Douglas rims
-Brand new Douglass rims with Sand Ghecko front and rear
mollmanhj is offline   Reply With Quote
Sponsored Links
Advertisement
Old 09-11-2010, 10:06 PM   #2
t web2007
Lifetime VIP
Send a message via AIM to t web2007
Default
I have this problem also, but it's only at the initial startup. I've also noticed that its tough to push the bike in gear with the clutch in. The problems seem to go away as soon as the engine is semi-warm. I think thats just thow hey are.
__________________
Troy
02 660r
FMF powerbomb & titanium 4, k&n no lid, vittos jet kit, streamline stabilizer, +6 lonestar axle, yfz shocks
t web2007 is offline   Reply With Quote
Old 09-11-2010, 10:17 PM   #3
mollmanhj
Junior Member
mollmanhj's Avatar
Default
That is exactly what my bike does. I makes me crazy. Do you know if there is a fix for it?
__________________
-Renthal bars
-K&N Filter
-Alba nerf bars
-ASV clutch lever
Old 09-11-2010, 10:20 PM   #4
t web2007
Lifetime VIP
Default
There is a little bit of adjustment if you pull the rubber cover off of the clutch lever. I like my lever a little sloppy. Rappys have a wet clutch right? The problem is probably a dry clutch until the oil gets to it.
__________________
Troy
02 660r
Old 09-11-2010, 10:33 PM   #5
mollmanhj
Junior Member
mollmanhj's Avatar
Default
That would make sense. I guess if not broke, don't need to fix it. Thanks
__________________
-Renthal bars
-K&N Filter
-Alba nerf bars
-ASV clutch lever
Old 09-11-2010, 10:40 PM   #6
t web2007
Lifetime VIP
Default
Might just want to get in the habit of starting it in neutral when its cold.
__________________
Troy
02 660r
Old 09-12-2010, 01:17 AM   #7
QuadManiac
QuadManiac's Avatar
Default
This is normal, and unless it is severe or does not go away when the engine warms up, there is nothing you can do about it, nor should you worry about it.
The clutch is bathed in oil that, when cold, is rather thick. The viscous oil between the clutch plates causes drag that tries to turn the driven plates even when the clutch lever is pulled (somewhat like a torque converter in an automatic transmission). This is completely normal. The thicker oil viscosity you use, the more you will notice. As the oil warms up, the symptoms should go away. If it is more than you like, drop your oil viscosity at your next change - like from 10W40 to 5W30.
__________________
'01 660 Raptor, Burgard +2+1 arms, YFZ Shocks, LSR anti-vibe, CTR pipe, jetted, K&N
'01 Polaris Scrambler 400, K&N
'02 Honda 400ex, Big Gun pipe, jetted, K&N, Lonestar +2 A-arms, Lonestar anti-vibe
'02 Honda 400ex, DiamondJ +3 A-arm widener, Lonestar anti-vibe
3 scooters - 150, 180, 250
'73 Yamaha CT3-175 Enduro (currently under restoration)
'08 Can-Am Spyder SE5 - my Baby!
And the newest toy destined to suck up all my spare time and money: 2000 Jaguar XJ8
QuadManiac is offline   Reply With Quote
Old 09-12-2010, 01:37 AM   #8
03LimitedEditionRaptor
Senior Member
Default
Quote:
Start it up in Neutral and dont shift it in to gear until the engine is up to normal engine operating temperature. You shouldn't be riding on a cold engine any way.
Jumping forward with a cold engine and dry clutch plates is 100% normal. The only way to get around it is to have the clutch improperly adjusted to tight, but then you will smoke the clutch from slipping it.
__________________
2003 Limited Edition Raptor
Kenz 720cc 11:1 stroker, +1 valves, Mega Cycle X-4 Cam, Sparks 6x Big Core, Keihin 35mm FCR's. 158 mains, 52 pilots, fuel screws 2 turns out.
97 Banshee
F.A.S.T. Dune Ported 4mill, CPI Inframes, Keihin PWK33's, Direct Drive Lockup. 158 mians, CEL needles second clip, #48 pilots, air scews 2.0 turns out.
03LimitedEditionRaptor is offline   Reply With Quote
Old 09-14-2010, 08:40 PM   #9
mollmanhj
Junior Member
mollmanhj's Avatar
Default
Thanks for the info!
__________________
-Renthal bars
-K&N Filter
-Alba nerf bars
-ASV clutch lever
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBadvanced CMPS v3.2.2
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Inactive Reminders By Mished.co.uk and FTP-Anime.com
