wont start, backfires - Raptor Forums: Yamaha Raptor Forums
» Sponsors
Go Back   Raptor Forums: Yamaha Raptor Forums > Raptor 660 Categories > General 660 Discussion
Reply
Thread Tools Display Modes
Old 11-17-2010, 10:56 PM   #1
j567488
Member
j567488's Avatar
Default wont start, backfires
Ok heres the deal. Bought a 660 from a buddy of mine..... don't remeber for sure what year it is. Awhile ago I looked up the vin but I can't remember for sure. Think it a 2001. Its white and black.
Anyway, before all of this, I got it and it would start really hard. always took awhile sometimes needed to use the battery charger to get it going. But it would start and run fine, after it warmed up it would always have a high idle, not just a high idle but a really high idle. Almost like quarter throttle.
I thought it was the carbs cause he said he hadn't ran it in a year. So.......tonight I took the carbs off and cleaned them. Did a bunch of research to make sure I did it right. Took a lot (A LOT) of time putting them back on to make sure the boots where right.
Now it seems like it wants to start but all it does is backfire. Got a new spark plug and it does the same thing. Seems like when I put the Choke on it "wants" to start more, but at the same time it backfires worse.
Any help please.
j567488 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 11-18-2010, 10:42 AM   #2
Banshee2Raptor
VIP
Banshee2Raptor's Avatar
Send a message via ICQ to Banshee2Raptor
Default
Any help please.
Clean the carbs again . Raptor carbs are very very picky. Wate mods are done to your bike, or is it bone stock ?. Also adjuust your valves, they have a habit of geting worn tight & will not start when cold or start very hard..
__________________
01 Raptor 686R, Willykiller 3 Pluger...2nd build under construction
Banshee2Raptor is offline   Reply With Quote
Old 11-18-2010, 11:11 AM   #3
rynb15
Senior Member
rynb15's Avatar
Default
deff clean the carb again. when i had my 660 it sat for 6 months and same thing. i could not get the jets clean enough. there is a yamaha dealer down the street from me so i just bought new jets. put them in and it ran better than new.
__________________
06 700
Full HMF Exhaust
Alabracing fuel controller
Pro-Tech moflo lid,twin air filter
yfz450 shocks,protaper bars
rynb15 is offline   Reply With Quote
Old 11-18-2010, 11:33 AM   #4
j567488
Member
j567488's Avatar
Default
I was told it has one less tooth on the front sprocket, the pipe doesn't have a name or logo on it but its not stock, doctor d reverse, the parking brake wire is disconected, the more I'm looking into this problem the more I'm learning about whats all done to the quad. I'm going to get new jets today and adjust the valves tonight. I'll lett you know how it goes.
Old 11-18-2010, 12:49 PM   #5
Banshee2Raptor
VIP
Default
Best of luck to ya. A pic or 2 would help to tell wate kind of pipe you have...How bout the air filter ? Any hols drilled in the lid ? Snorkel on or off ?
__________________
Old 11-18-2010, 06:50 PM   #6
j567488
Member
j567488's Avatar
Default
STARTS!!! Adjusted the valves, that seemed to solve the starting problem. Now I have gas pouring out of the overflows of the carbs. The idle is really high still. I put the choke on and it seemed to want to idle, so I guess that means its running to lean Ordered a carb rebuild kit today, still gonna try to take the carbs apart again and see if that works.
Any other ideas??
Old 11-18-2010, 06:53 PM   #7
j567488
Member
j567488's Avatar
Default
oh yea, there are no holes drilled in the airbox. looks stock to me. when i was at the dealer today i looked at the exhaust break down pic and it appears i have stock
Old 11-18-2010, 07:37 PM   #8
tmc
VIP
tmc's Avatar
Default
Any other ideas??
floats might be stuck
__________________
2001 Raptor 660R
Monster Duals
CFM Aluminum Air Box-K&N Air Filter with Outerwears (No Lid)
Vito's Jet Kit with Dyno Jet Needles
160L/165R Mikuni Main's
#25 Pilots
Fuel Screws 2.0L/2.0R
Flipped Rear Link
Asv Levers
Pro Design Shifter
CFM aluminum oil tank
GYTR Skids+Heel Guards
Fasst Flexx Bars
Diamond J Widening Kit
Terry Cable Dual Gasser
tmc is offline   Reply With Quote
Old 11-18-2010, 09:11 PM   #9
j567488
Member
j567488's Avatar
Default
OK!! First of I'm a f ing idiot, me and whoever screwed it up in the first place.
SOOOOO.......cleaned the carbs again and that stoped the fuel leaking problem. Adjusted the valves so it pops off right away. AS FAR AS THE HIGH IDLE. I didn't see that the damn idle screw is BROKE OFF..... Got a new one coming, gonna have to figure out how to get the broke one out cause its so f ing coroded in there. So for right now i just filed off a little bit on the stop end and it is running fine. Need a new throttle cable also cause this one seems to be sticking. But when i have the cover off where i can get at the cable on the side of the carbs, after i start it and it does that high idle i just mess with the butterfly "valve" and it returns to normal. I think i have it set well enough to get me threw the weekend.
THANK YOU ALL VERY MUCH FOR YOUR HELP. I just need to look more carefully at the details.
Thanks again,
Josiah
Old 11-18-2010, 11:59 PM   #10
QuadManiac
QuadManiac's Avatar
Default
So nice when the story ends happy!
__________________
'01 660 Raptor, Burgard +2+1 arms, YFZ Shocks, LSR anti-vibe, CTR pipe, jetted, K&N
'01 Polaris Scrambler 400, K&N
'02 Honda 400ex, Big Gun pipe, jetted, K&N, Lonestar +2 A-arms, Lonestar anti-vibe
'02 Honda 400ex, DiamondJ +3 A-arm widener, Lonestar anti-vibe
3 scooters - 150, 180, 250
'73 Yamaha CT3-175 Enduro (currently under restoration)
'08 Can-Am Spyder SE5 - my Baby!
And the newest toy destined to suck up all my spare time and money: 2000 Jaguar XJ8
QuadManiac is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBadvanced CMPS v3.2.2
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Inactive Reminders By Mished.co.uk and FTP-Anime.com
