Ok this is my very first post, My raptor that I just bought from a guy like 2 months ago had been starting fine, one day I go to the garage to start it and all it does is pop and back fire, eventually tore the carbs down and cleaned them, nothing real bad, now that I put it back together it turns over but wont stay running, I actually stayed on the gas and it stayed running, as soon as I got off the gas it kills, sometime it will stay on, sometimes it wont, any suggestions?
Welcome to the forum! Is this your first four wheel or raptor 660? Make sure that your carbs are fully seated in the boots. A big backfire can cause them to pop off and then your bike wont run or it will run very poorly
__________________
2002 Yamaha Raptor 660
DG Alloy Series Nerf bars
DG front bumper
DG full under and A arm skids
GYTR slip on exhaust
Jetted
Turf Tamers
I had an issue like this, my raptor wouldnt stay on and wasnt getting full power. The wire that is connected underneath the front sprocket was my problem. All i did was tighten it up and it ran fine. Just a possibility takes 10 seconds to check.
Possible parkbrake rev limiter is coming on, check the switches by the park brake handle or just disconnect the wires from the main harness and seal the plugin............ green and yellow wire and a black wire
__________________
686 three plugger with HV porting, 39 FCRS, Curtis Sparks exhaust, Dyna FS CDI
Read "Most Common Problems with the Raptor 660", a sticky at top of the General 660 Discussion section - pay attention to the RPM limiter section, as Willy has suggested. Does this sound like your problem?
__________________ '01 660 Raptor, Burgard +2+1 arms, YFZ Shocks, LSR anti-vibe, CTR pipe, jetted, K&N
'01 Polaris Scrambler 400, K&N
'02 Honda 400ex, Big Gun pipe, jetted, K&N, Lonestar +2 A-arms, Lonestar anti-vibe
'02 Honda 400ex, DiamondJ +3 A-arm widener, Lonestar anti-vibe
3 scooters - 150, 180, 250
'73 Yamaha CT3-175 Enduro (currently under restoration)
'08 Can-Am Spyder SE5 - my Baby!
And the newest toy destined to suck up all my spare time and money: 2000 Jaguar XJ8
