660 timing chain tension adjustment - Raptor Forums: Yamaha Raptor Forums
» Sponsors
Go Back   Raptor Forums: Yamaha Raptor Forums > Raptor 660 Categories > Raptor 660 Maintenance
Reply
Thread Tools Display Modes
Old 12-18-2011, 10:00 PM   #1
oldmaster02
Junior Member
oldmaster02's Avatar
Default 660 timing chain tension adjustment
ok so i really need somebodys help here i just bought a 01 660 with 04 bottom end and it was claimed to have an 11:1 piston, new cam chain, stage 2cams, and valve spring kit. I rode first day and 4hrs into my ride i heard a rattle from the top end dicided to stop riding and check valve adjustment and was below factory spec adjusted it to hot cams stage 2 spec got worse decided to pull valve cover found no parts were aftermarket and chain was a sloppy mess so now am in process of replacing my big question here is how do i remove slack on the exhaust side of chain obviously intake slace is removed by tensioner but is there a step im missing because all the forums of read mention nothin of removing slack except with tensioner thanks for your help much needed
oldmaster02 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 12-23-2011, 06:08 PM   #2
QuadManiac
QuadManiac's Avatar
Default
remove the tensioner... turn the cam - both sides are now slack. Upon re-assembly, turn cam gear CW to take up slack on front - NOW verify that cam is properly timed to crank, then install tensioner (after bolting down head cover) to take up slack on back.
__________________
'01 660 Raptor, Burgard +2+1 arms, YFZ Shocks, LSR anti-vibe, CTR pipe, jetted, K&N
'01 Polaris Scrambler 400, K&N
'02 Honda 400ex, Big Gun pipe, jetted, K&N, Lonestar +2 A-arms, Lonestar anti-vibe
'02 Honda 400ex, DiamondJ +3 A-arm widener, Lonestar anti-vibe
3 scooters - 150, 180, 250
'73 Yamaha CT3-175 Enduro (currently under restoration)
'08 Can-Am Spyder SE5 - my Baby!
And the newest toy destined to suck up all my spare time and money: 2000 Jaguar XJ8
QuadManiac is offline   Reply With Quote
Old 12-23-2011, 06:21 PM   #3
willykiller
willykiller's Avatar
Default
Quote:
Originally Posted by oldmaster02 View Post
ok so i really need somebody's help here i just bought a 01 660 with 04 bottom end and it was claimed to have an 11:1 piston, new cam chain, stage 2cams, and valve spring kit. I rode first day and 4hrs into my ride i heard a rattle from the top end decided to stop riding and check valve adjustment and was below factory spec adjusted it to hot cams stage 2 spec got worse decided to pull valve cover found no parts were aftermarket and chain was a sloppy mess so now am in process of replacing my big question here is how do i remove slack on the exhaust side of chain obviously intake slave is removed by tensioner but is there a step i'm missing because all the forums of read mention nothing of removing slack except with tensioner thanks for your help much needed
I'm not sure what you are asking for here, but chain tension is automatically adjusted by the chain tensioner located at the left lower part of the cylinder. This can be removed by removing the two fasteners and pull it out, if you want to see how far the tensioner is at, remove the big bolt and spring in the head of the tensioner previous to removing the tensioner.........
__________________
686 three plugger with HV porting, 39 FCRS, Curtis Sparks exhaust, Dyna FS CDI
willykiller is offline   Reply With Quote
Old 02-01-2012, 04:29 PM   #4
J00F150
Senior Member
J00F150's Avatar
Default
Mine is making the ticking noise also, if I take the self tensioner out, and check the notches, after checking, I can just but back in the same way with out making it of time.
__________________
K&N air filter
MQ parking brake block off blake
Pro Taber bars, 7/8
Vito's performance jet kit
Boss a arm bushings
ODI hand grips
Pro Design Case Saver
Tusk Handquards
L&A one way bearing kit
Tusk Nerf Bars
Tusk Headlights
J00F150 is offline   Reply With Quote
Old 02-01-2012, 05:14 PM   #5
willykiller
Default
Quote:
Ther cam to crank timing shouldnt change unless you turn the engine over and force the chain to jump over the teeth on either gear, when this is possible, most likely you chain is worn out.............
__________________
Old 02-04-2012, 02:12 PM   #6
J00F150
Senior Member
J00F150's Avatar
Default
Quote:
So i guess the tensioner does not brake or quit working usually willy?
__________________
K&N air filter
Pro Taber bars, 7/8
Boss a arm bushings
ODI hand grips
Tusk Handquards
Tusk Nerf Bars
Tusk Headlights
Old 02-04-2012, 03:29 PM   #7
willykiller
Default
I have personal experience with a tensioner breaking under race conditions, engine rpms were between 6500 and 9000 rpm for extended periods of time.
The ratchet mechanism broke, the chain was tight when the engine was stopped but probalby wouldnt be that tight under run onditions, it was only the spring holding the chain tight............
__________________
Old 04-14-2012, 11:07 PM   #8
J00F150
Senior Member
J00F150's Avatar
Default
I replaced my timing chain, I found the rocker cover bolt torq specs, but is there a certain pattern they should be torq in? And since I just adjusted my valves two rides before doing this so I adjust them again when i get everything back together?
__________________
K&N air filter
Pro Taber bars, 7/8
Boss a arm bushings
ODI hand grips
Tusk Handquards
Tusk Nerf Bars
Tusk Headlights
Old 04-14-2012, 11:08 PM   #9
willykiller
Default
Yes...............
__________________
Old 04-15-2012, 03:07 AM   #10
J00F150
Senior Member
J00F150's Avatar
Default
Ok yes on both, what is the pattern I should follow with torq down on cover?
__________________
K&N air filter
Pro Taber bars, 7/8
Boss a arm bushings
ODI hand grips
Tusk Handquards
Tusk Nerf Bars
Tusk Headlights
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBadvanced CMPS v3.2.2
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Inactive Reminders By Mished.co.uk and FTP-Anime.com
