1 - 20 of 20 Posts
i have a 01 660 with a pipe and jetted carbs k & n . Last ride was great until it stalled, now it will only fire up with a squirt of starter fluid and will barely run popping and backfireing. Carbs were taken apart cleaned and rebuilt using existing bigger jets from previous owner who abused it with little or no maintenance. pilot jets are adusted according to book. Should i do compression check first ? wanna ride please help.
~~~ 660 Specialist ~~~
Have u bypassed the parking brake and reverse limiter??? To me it sounds like one of the 2
Check your boots. sounds like one has popped free.
Discussion Starter #5
Wow thanks for the quick reply to everyone ! I'm not sure what the parking brake and the reverse switch has to do with my performance issue. I'm willing to try anything, would anyone be able to give me a little direction with this as far as how to bypass brake and limiter, thanks again for the help.
+1. It sounds a lot like your boots came loose or something... I had the same problem and it was my boots
The rev limiters keep the engine from revving when you are in reverse or the PB is on. A common failure in one of these circuits will cause the limiter to be on all the time. This causes the engine to sputter when you barely get on the throttle but has NO effect on starting or idle.
This is NOT your issue. You can't even start your bike. My bet's on the boots.
Ok I just figured since he was there squirtin starting fluid he would notice the boots, but I guess I would probably miss them
Try disconnecting the voltage regulator, if this solves your problem, your stator is at fault.......
Ah... could the Phantom be at work again? I don't think so in this case, since he gets it to run (sort of) with starter fluid. BUT, I've been surprised before.
You know something, we had an F150 Ford come in to our shop this week, the engine would not start, when you turned it over it would spin and lock up, we changed the coil pack, plug wire and sparkplugs, then the truck would try to start without lockup, I disconnected the breather and the truck would sit there and run when I sprayed ether into the intake, I then noticed that the serpentine belt had just loosened, the engine's harmonic balancer and reluctor wheel had just broke of the crank. Problem solved........
So it basically ran without spark...........
Discussion Starter #13
i really want to thank yall again. but i disconnected the parking brake wire and grounded the reverse wire and still nothing. not even with starter fluied. im i gunna have to take apart the top end?
I just read your first post again, you said it stalled, try turning the piston to the top, remove the sparkplug, and put a long skinny screwdriver into the sparkplug hole, turn the engine over by hand until you determine that the piston is at the top, you may have to rock the crank back and forth a bit to determine this, then check to see if the timing mark on the flywheel is still lined up with the mark on the flywheel cover. If not your key is sheared between the crank and flywheel, this will make it hard to start........
Discussion Starter #15
yall i got it runnin.runs like never before!!! turns out that it was shorting out at the c d i box.some wires had got busted from the batt bounceing around.thank every one for there help.this is the best web site ever!!!!
Ok gonna see if anyone has a solution.I have a 02 660 kandn open lid mod a full exhaust and is jetted to mods.Ran like a rappy should even when valves where worn tight.Was out riding running on trails so not wide open or anything serious and noticed i was getting a miss around half to full thumb.Ok no biggie went home changed plug notta still doing it but backfires now and falls on its face at over qrt thumb..WTF now so I adjusted the valves to spec .127 with my feeler gauge set avg. out .100 to .150.Hmm again same start up was about the only improvement.Pulled carbs cleaned with cleaner air nozzle ran copper wire threw all the jetts ports etc.Same but progressively seems worse.Sorry if this long but tring to go threw what Ive done to saveface..Anyways like I was saying completly did the whole ringer on this thing and I have done the rev limiter delete aswell..The only thing I can think of is when I bought it had a full tank of fuel not sure what octane it was but before I went out it had maybe qtr tank so I topped it off with 91 that I run in my cannondale 440 speed that I just filled my jug with.Dont think it makes this big a perfomance effect..So before I start tearing the case off to check woodruff and flywheel teeth any suggestions..Starts right up idle is smooth runs smooth kinda at topend also but not so much..Feel like I might an internal problem.
So, you just bought this and the problem started on your first outing?
You must rejet with an open airbox.
1 - 20 of 20 Posts
