what should it be?
I have a 01 raptor 660 that I took out this weekend and it work fine. But when I got home my reverse light was flickering on and off. Then when I go and ride it. It just dies out, but when I rev it the reverse light just goes always and it works fine. But when I slow down it can back again please help me!!
WTF is this poll for? The results will tell you nothing. Classic noob misuse of a forum.
BTW, WELCOME TO THE FORUM! :D
Your reverse switch connection is loose/dirty at the switch. Find the green/white wire with a right angle push on plug, plugged onto the switch, just under the output sprocket. Unplug, clean the connections, squeeze the spring contacts in the plug and reinsert it. VOILA - your flicikering light will be gone AND the reverse RPM limiter will be gone also - this was causing your crappy running above idle.
It will.
