So I’ve had my raptor for almost 2 years now and after I did some work with the ignition coil it will now start up but then after I let it warm up for about 5 minutes it just dies on me. It sounds like it is losing fuel almost. I checked the fuel delivery then tore into the carbs and they look great. I have looked at many other posts on here and I am dumbfounded any help is appreciated
Discussion Starter #2
Could it be the valves? That’s one of the only thing I haven’t checked and was curious about that. The only reason I’m skeptical of that is because I have never had trouble with those
Not likely valves. You're either losing fuel or have an electric problem, IMO. Unplug the regulator. Does it still die after 5 minutes? Try loosening or removing the fuel cap...
When it dies, how long till it starts and runs again? What must you do to get it running after it dies?
