I have an 02 Raptor with NO SPARK. I did all of the checks on the coil and the stator and everythings appears to be in spec. I also did some of the other tests where you disconnect the rectifer and still no spark. I then started to check all of the connections and I found under the CDI two wires that rupped together and bare wire was exposed it was the orange wire and the red wire with a black tracer. My question is would those two wires being in contact with each other casue something in the CDI to blow or fry? I was riding the quad and all of a sudden it just died while riding in third gear getting ready to hit fourth. Somebody please HELP!!
possibly shorted out the cdi repair the wires and try another cdi if you have one....or have a friend that has one
Red/black is 12V supply to the CDI. Orange is 100+V pulses to the coil. Shorting the two together COULD damage the CDI. I'd repair the shorts and try again... and if no success then borrow an 02+ CDI (don't use an 01) to see if spark returns.
Thanks for the quick responses I am going to have to spring for a new one is there any that you recommend or just stay OEM the bike has a jet kit an full pipe.
OEM's are available regularly on eBay for $25 or so -make sure to get an 02-05 year, the 01 won't work for you.
Git-R-Done
I have a 03 cdi, 30 bucks + shipping if you need one. pm me if you are interested.
