Hello everyone, I am new to the raptor world. I have an 03 660 and when I first got it it was leaking gas out the overflows. I took the carb apart, cleaned the float needles and jets. It now doesn’t leak but I still have no response through the mid section of acceleration.could this be a hole in one of the diaphragms? Thanks in advance!
Probably need to adjust needle level
Depends if your lean or rich. I would try moving clip down one slot. This will richen your mixture. If thats worse go up one from original. That will lean it up.
You can go ride it and roll on the choke and see if it runs better. If it cures bog some in mid range richen the needle if worse lean the needle. Make sure float level is correct also
