Having some coolant issues apparently.
When in neutral, or when the clutch is pulled in, the light is off. As soon as I let out and get some forward momentum the light comes on and stays on as long as I'm riding.
I have no coolant leaks that I can detect. The water pump is circulating. I'm out of ideas at this point.
Also, the radiator fan does not come on. Bike is bone stock.
Thoughts?
Sounds more like an electrical issue to me.
Have you downloaded the service manual? The wiring diagram is last page or so - shows all connections and wire colors. Look at light blue (nuetral switch) and black/yellow (clutch switch).
Also, our fans almost never come on - test by placing piece of paper over radiator - let idle for about 15 minutes... fan should come on for a minute or so then go off for several, then back on and repeat.
