I have a slight problem. My brakes pads are scrubbing my rotors after I installed new brakes. I'm trying to figure out what the item maybe. The rotors doesn't appear bend. Any suggestions?
Did u clean up the brake pad glides?.?
Maybe ur caliper is sticking...
Sent from my SAMSUNG-SM-J327A using Tapatalk
Discussion Starter #3
I did not do that. I just took out the old ones and replaced the new ones. I did bleed the brakes lines and put fresh fluid in. I'll try cleaning the glides. Thanks.
Front, rear or both?
Discussion Starter #5
Front brakes. The issue is fixed. The metal clip was not staying on the backside of the brakes. The piston was pushing the pads but they were not retracting. I also cleaned both brake calibers. Thanks for the comments.
Good find! Welcome to the Forum!
