1 - 1 of 1 Posts
Hey just got her up and running, installed a new kg factory clutch, I want to be sure its adjusted right. It starts engaging with about 1/4" of space between the lever and the housing where lever mates with when the clutch is let out all the way. Also it seems to want to cut out alot more when opening it up towards the bottom end ever since the clutch went out. Do pilots just randomely plug up? Just a thought. Only diff is, I started using turbo blue last gas up.
thanks
1 - 1 of 1 Posts
