Find the black/yellow and black wire pair with bullet connectors - up behind the radiator - are they plugged into mating pairs of bullet connectors with a pair of black wires? If so, then the switch is probably bad... unplug them from the switch and and plug the two harness ends into each other instead - does it start in gear (even without pulling the clutch) now? Definitely the switch is bad.
If they're not connected to anything, either find their mates or, if you can't, perhaps the switch has been removed - plug them together as above - it will start in gear now - just be careful.
