So I am in the process of rebuilding an 06 700. Beat to shit by previous owner(picture don't do justice). Sat for 6 years after the abuse it was put through, so I am giving it new life. I have stripped it down to the frame and I am working my way up. I have all my suspension painted with new bearings, orings, ball joints, etc. Putting it all back together the last few days. I am trying to not break the bank with this build, but I am trying to have a reliable bike as well. I plan on tearing the motor down completely and check all components on the inside, replace what's needed and keep it stock. I've done lots of reading through the forums on here but everything I keep reading is out of date. I am still in need of a lot of parts like chains, brakes, brake rotors, fuel pump, radiator fan, tires and clutches are getting changed no matter what they look like.
So for most of the suspension I bought OEM parts from Partszilla about 1150 so far. Looking around I've found aftermarket parts cheaper, for example Partszilla OEM ball joints are 42 a piece, all balls are 22 a piece. I know you get what you pay for, but I've also found that newer model 700's also have cheaper OEM parts the my 06. So through out all the years from 2006-2021 what parts can be swapped over with little to no modifications? If every part on the newer models would fit my bike I would buy all OEM but that's not the case.
Is there a website that sells good quality aftermarket parts for a good price? What companies do I need to stay away from?
I've posted some pictures below so ya'll can see the progress.
