1 - 2 of 2 Posts
I had this earlier this year with a PC3 programmer, it turned out the TPS was out of whack on the programmer, it thought the throttle was at 100% dumping way to much fuel at idle. I ended up re setting the TPS on the programmer and it solved the issue. I am not sure how the quad work programmer works, or if it even has throttle position on it. You may want to dig out the book on it, and check it out.
1 - 2 of 2 Posts
