Rebuilding my 2006 700, so I stripped all the parts out of the motor to be cleaned and installed. My question is since I removed the valves do I need to get them lapped or they should be good to go back in since I did not replace any of those parts?
you already have it apart buy some lapping compound use a small piece of gas line and put that on the end of your valve so you have something to spin the valve with or by the lapping tool on AmazonRebuilding my 2006 700, so I stripped all the parts out of the motor to be cleaned and installed. My question is since I removed the valves do I need to get them lapped or they should be good to go back in since I did not replace any of those parts?
