21 - 25 of 25 Posts
Discussion Starter #21
They didnt say. They wouldnt take it apart after hearing it crank. Nobody has every taken the engine apart. Ill have to take it out myself.
Pull the head and cylinder per your manual.
Need a manual, pm Morphrider with your email.
You'll need basic metric hand tools and a torque wrench.
Always use a factory head gasket, about $35. Base gasket is about $15, timing chain $25, CP piston $225 (?), cylinder hone about $25. Cylinder recoating is around $300.
These prices are estimates, a crank will come with one new bearing, but, I haven't kept up with prices. You'll need a tube of Yamabond, clutch and stator gaskets, maybe a valve job.
You need a flywheel puller, clutch basket pliers, valve spring compressor, calibrated torque wrench, and a piston ring grinder, as well as basic hand tools too.
Discussion Starter #25
Hey guys, I need a full engine rebuild. Probably going to cost me $2k. I was going to ask them to just do the bottom end while I did the top end but apparently I dont have the proper tools. Does anybody know of a complete engine rebuild kit that has EVERY part needed?
21 - 25 of 25 Posts
