Valley Boy
So I just picked up a 07 raptor SE the other day, it has a k&n filter on it and has a hole in the top of the lid with a screen over it as well as some ebay genesis "chip". I have been looking around to see what people are saying regarding fuel controllers and have read that the hmf optimizer (dobeck style?) is not a great system. I am thinking about finding a stock lid and leaving it alone for the time being and maybe someday upgrade the exhaust and do a fuel controller then (power commander seems to be a popular choice). So the thing I was trying to find out was regarding target a/f ratios. I can't seem to find anything concrete so I thought I would post the question. I did read sometime over the past few days that 13.2: a/f would be good but would like some more insight. I have an aem wideband for my car which is having a new turbo downpipe made so the wideband is out of the car at the moment and was debating on setting it up on the raptor to see where I am at. If I can't do that I may throw the wheeler on the truck when I take the car to get it tuned and get the wideband setup on it then. Anyways, if anyone could add some insight I would appreciate it.
dont use the aem wideband,they are to slow and will end richer than you want,use innovate products,if use the innovate 12.5-12.8,if you go to the dyno then 13.2 is a good point if the dyno wideband is in good shape and properly calibrated,most time they are some off.believe me i have over 15 years in the tuning industries,and never ever have seen 2 dynos reading the same afr when my innovate still read same afr,and in P.R we have over 12 dynos all near sea level,so tuning is very accurate anywhere you go.
Valley Boy
Everyone has their preferences on the brand. The dyno that I get my car tuned uses a innovate but the AEM uego is a nice piece as well. As for slow I do believe their response times are close to one another. I understand each wideband can read different, as well as 2 dynos will give 2 different results (as my car made a few more hp on one dyno vs another even though they were both dynojets). Anyways, I was looking for a target a/f just to make sure I'm not running lean. I am going to pull the plug today and check the color to see how it looks (I bought new plug anyways).
xskater - PM sent
Valley Boy
Pulled the plug, thought I would post up a pic of them. I just ordered a new lid for it so there will be no hole in the top, which is better for me as I will be riding it a lot of wet areas. May restrict the flow a bit but rather not take the risk running lean.
If it's too loud your too old
I've got the AEM and it's mounted permanent, it runs 13.0-13.2 and the plug stays a nice choc. brown with 104 unleaded CamII. Response is fast probably because I have the O2 mounted in the head, it reads almost instantly!
