I just finished searching all the archives for the answer to this question ...didnt find it If i do the 5 step speed sensor override will the speedo on my 09 700 work or will it read 0 all the time.
Your speedometer will still work.
I'm pretty interested in this.
So, really, you confirm the speedo will still work fine?
how does the speedo know how fast your going does it use just a speed sensor or a combination of that and gps ???
There's no GPS on a stock bike, I'm pretty sure of that.
If the speedo still works with the wire cut, then I'm guessing the sensor just tells the ECU if it's in 5th gear, which retards the timing at 6500 rpms or so. And there's something else giving speed readings to the speedo. Am I right?
