1 - 10 of 10 Posts
I have been riding the vforce 700 for a few years now and just picked up a left over 06 anniversary raptor. I don't have but 5 min on the thing and have been reading about the front sprocket swap. The shop tells me I must change my chain if I swap the sprocket. Can someone help me out an confirm this. I have seen alot of chatter or people making the switch, but nothing about the chain. I will ride primarily sand with this one. Thanks in advance!
The shop is full of shit go ahead and swap it out. I did it with about ten hours on it and there hasn't been one problem. It's worth it.
If its still stock and you ride sand, I would stick with the 14T. Even with the 3 mods, the 15t is a tad high for serious duning / hillclimbs. On dirt, it wouldnt be an issue but sand robs power.
You can swap out the front sprocket without swapping out the chain. Theres plenty of slack in the stock chain...You'll need a 36MM socket to get off the nut. :thumbsup:
Yeah sorry didn't see the sand thing I am primarily dirt, rock , and mud.
+1
The shop prolly wanted to sell you a chain...... :confused:
Welcome to the site..... 8)
Are Ya Jealous
when you say "duning/hillclimbs" do you mean dune hillclimbs or jus hillclimbing in genereal?? hillclimbing is my thing, long hills, creek banks or jus tryin to get to the top of a hill side that has no trail on it....so would the 15t not be a good idea for me?? cause the way these guys talked in one of the 15t forums which i can no longer find, really made me want to change mine out........
I dont know what you guys are talking about my 15t is awesome in the sand! It keeps the quad in the power band longer.
Super Moderator NW Raptor Rally Coordinator
If you go to a 15 with a stock raptor 5th will fall on its face in the sand,for most raptors and in the tree shots it can bog out. Now if you go big 3 this will help but add a good cam and port with that and the 15 runs great. When I was stock the 13 worked great for the tree shots ( flip you over backwords tree shots). Also a vast amount of this information will change with the type of tire you are running. Hope this helps out.
I like the 15T better in the dirt...but had to swap it back in the sand. It wouldn't pull as hard and seemed to bog down. I think rider weight plays a big factor. I weigh 225, from what I have read the bigger guys aren't as happy with the 15t until you really start modding. I am thinking about dropping to a 36t in the back (with the 14t front) to try and go somewhere in between.
1 - 10 of 10 Posts
