hi all igot my 15 tooth sprocket today but cant find how to loosen my chain ive searched the forum but cant find it can any one help me out thanx
loosen the four allin bolts ant the rear of you swing arm. then look at throught the sprocket and youll see a hole for a screw driver. stick the screw driver throught the sprcket into the hole. now push or pull the wheels on the bike to loosen or tighten. you should find the URL for the service manual on here. hopefully someone will post it for you
Just like you said. The first time might be a little confusing but after that, it is the easiest thing to do :thumbsup:
When loosing the allen bolts the service manual gives a sequence
loosen tighten
0 0 0 0 0 0 0 0
2 4 3 1 3 1 2 4 numbered order to loosen and tighen
:thumbsup:
