Did you put the case saver in the second hole? There are two holes on the top mounting area and you need to use the other hole after you add the 15t. I personally just grinded mine down a little bit because It looked to close for comfort.Chet said:i just looked again and you can see the chain like catch and and get slack or something... i read somewhere on here that some people have the trim something when putting the 15t on, could mine be hitting and making the chain jump ?
Ya, the chain is fine.upsguy said:tera i just bought one. you dont have to add links or anything to the chain right. just adjust it like the manual says?
Sorry to go off topic but I've noticed "the timing chain noise" getting more prominent over the last few rides. Booked in for 20 hour service next week, is there anything that shouls/could be done or do I just live with it?Teraflx said:Its probably the timing chain inside the engine. Its a common noise on the 700's.
