1 - 16 of 16 Posts
Was wondering what a +6 swingarm looks like on our bikes? Would it be over kill for mainly a trail bike? I'd like to do atleast a +4 because when I do race it its on the street.... Any advice?
i run a +4 and i mostly trail ride with some drag racing mixed in and it does great. just remember you will need to get the rear shock revalved with a +4.
mike
mike
:thumbsup: Yep, I run a tucker +4.
+2 worked out perfect for my bike. I ride mostly trails, with some mx mixed in. It really tamed it down on hill climbs and the unpredictable wheelies. On a tight budget, extending the stock +2 ran me right around $100 with new chain purchase.
how did you extend the stock swing arm? did you have to take it to a welding shop or did you do it yourself. i was thinking of extending mine as well
I had a friend do the welding. Anyone that can weld aluminum should be able to do this (a reputable welding/fabrication shop)
bought the material from a shop on ebay called speedymetals. I can give you more info if you want..ill have to dig up the receipts.
The +2 is the best trail length and good for most semi-stock machines IMO, and should have been the 660's original length. Excellent in trails and still carves well while keeping the nose closer to the ground more often.
The +4 does a good job of keeping the nose down, when you want it to. It can still bring it up with a decent amount of power, which most with extended swingers have. It's still agile in the trails and allows for confident powerslides.
The +6 is really starting to enter straight line territory, but it's not useless in a corner. My bike will bring the front end up, but it's rarely dramatic and always short lived. With a widened machine it's still quite laterally stable and capable of spinning round. In the trails I find it fine on the long, wide sections but have tagged a number of trees, stumps and rocks with the back wheels when in tight conditions.
OEM Extended 2 inches:
Houser +4:
Alba +6:
mike
[/quote
Who can revalve the stock rear shock for a +4 swingarm? thnks
I love that CT graphics kit. Second best only to the Skin one, which is too hardcore (it represents Hardcore, low-life MXers where i live.
NewJerseyRaptor said:
what where the deminsions of the material that you got from speedy? ex.square tube, block?? and what type?? aluminum,alloy,steel???? Thanks :thumbsup:
Solid stock 6061 aluminum
3"x6" 2" thick
sheet 6061 aluminum
12"x12" 1/4" thick
1 - 16 of 16 Posts
