1 - 14 of 14 Posts
I've been reading but really haven't found any answers to my questions so far. I ride mostly loose gravel and some hard pack dirt trails, Im wondering if it would be worth investing into some +2 A-Arms from houser long travel. any input would be a ton of help.
Ridin High.....
most trails have a 50in limit...
if you wanting a full LT front end setup your lookin at around 2k new (shocks, aarms, brake lines, ect). for the riding you described id go with some ST travel +2 a-arms and some SE OEM shocks (rebuilt to your spec would be even better). that would be below half the cost of a LT setup. all depends on what your budget is...
I run LSR but there are many other companies that make quality a-arms. Houser is a great company. check out KBMATV.com, he has premade kits...
I agree with Adam based on the riding conditions you posted a standard travel setup should meet your expectations. I'd go with a set of +2 a-arms for the extra corning stability. Although, if the loose gravel has rocks the size of your front rims you may want to forget what I said about going standard travel, and go with a stabilizer and a good long travel kit. Give us a call at 270-774-1982 if I knew more about your riding area I'd point you in the right direction.
Thanks Adam for the name drop!
Regular or LT there Grover? Which brand how much I'm wanting some but wanna stay 50inches max width what is it from factory(width up front)
Thanks I don't think I need long travel as I don't go over anything the rear axcel would hang on or really air it out just need a little stability in corners on the regular +2 are the shock mounts in the same position/place so geometry ain't affected?
well im stationed out in Colorado springs so its mainly hills. but when im back in iowa its flat trails with alot of speed i weigh in about 190 with all the gear on. I hope this helps you with figuring out what would fit me best
You ever run the road upto pikes peak? That's a dream of mine. Before I'm 50 I'm doing it sorry for jacking thread.
You can go with +2 arms easy and fit on 50" trails. If for some reason you are to wide get a set of 4+1 offset front rims. I run a +2 a arm for flat track racing and run the 4+1 rims and iam AMA dirt track 50" legal
Discussion Starter · #14 ·
ya pikes peak is amazing ive got to watch the rally racing there before and they have giant coin purses for the speed and no guard rails
1 - 14 of 14 Posts
