ok.. me and a friend of mine just got our mods..
Mine
1. White Bros Aluminum ProII
2. Pro Design pro flow
3. PCIII with fuel moto custom map
4. Protec Mo Flow lid
His
1. HMF Sport series
so we installed everything except my exhaust, cuz we wanted to to test the diff. between a modded raptor and one modded running on stock exhaust with baffle out.. anyway..
installation went fine.. we finished both bikes in 4 hours.. the problems came up with the power commanders..
the first problem was with my friends quad.. the exhaust kept back firing and giving black smoke... not to mention sometimes just shutting down.. first thing i did was d/l all the maps from the PC website.. hooked the laptop to the PCIII and saved the fuel moto map for future reference.. and loaded map m416-027. it's the closest that suited the mods.. anyway after that was done.. the quad finally started responding in a better manner.. but we still had an issue of backfiring.. the quad will only back fire in high rpm's, if in neutral and revving hard it will back fire with a big flame.. and when shifting from gear to gear in high rpm it will also give a big flame.. could it be that we need a better map??.. it was aparent that the fuel moto map was simply crap.. that was one problem.. the second problem which was common for both quads was the accellerator pump.. whenever i tried enabling it it says pcIII not connected.. i really haven't researched this issue much simply for time constraints.. i'm trying to figure it out while writing this.. but i am in the dark with this issue..
the last problem was with my bike.. also concerning the PCIII, when i connected the laptop the PCIII had no map in it to begin with.. which was very dissappointing.. i wont need it for the time being cuz i'm still running stock exhaust with baffle out... anyway i downloaded the map m416-003 Stock exhaust with muffler insert removed Stock air filter Airbox lid removed, the problem with this map is that it's for stock air filter and i am running pro design pro flow with K&N, the quad back fires on deceleration.. but it runs fine.. i need to get the map with the air filter that matches mine, so if anyone could help me out i would really appreciate it.. i am yet to contact fuel moto for my original map and see what went wrong.. and try to firgure out the accelerator issue.. i hope you guys can help me out.. peace..
Mine
His
1. HMF Sport series
