I need a little help with my raptor. I have read other similar posts about this problem and I am still a little unclear on what to do/buy. I looked at a schematic and found an oil seal, o-ring, and a collar do I need all three? And not sure if not sure what surrounds the splines on the output shaft is the collar or not. Direction/advice would be greatly appreciated. Here are some photos
Discussion Starter #4
I only see the oil seal and how do you pull that out? And would I need to pull the collar off that surrounds the splines and the sprocket gets pushed up against?
o-ring goes on shaft, seal goes into case, collar fits over o-ring and into seal - sealing both inside and outside.
