Alright, i have an 03 Raptor 660 that has sat for oh, 9 years give or take a year. It ran with no real issues when it was parked. It had "bogged" at high RPM (hill climbing) on me a couple times but only a few times... in hindsight now maybe this was related.
Back in 03 i had bypassed the reverse limiter ( cutting a green wire and running it to negative battery post) and also there are wires near the key/handle bars on right (sitting on machine) that if i remember right were for a park brake or neutral switch... i have a black wire and black w/ yellow stripe connected together. and then 2 black wires individually taped up. Quad is piped (Looney tuned dual), jetted, proflow filter, sproket, custom airbox, and dynatek F.S. Digital Ignition CDI)
so forward to a week ago, did a bunch of maintenance to see if i can get it running ( oil, antifreeze, gas etc). went to try and start it and the fuse in the solenoid would blow as soon as key turned on. it would not blow with the kill switch engaged. so i replaced the solenoid. a note here about that. the stock one had 20a fuses, while the new one had 30a.
once i replaced the solenoid i turned the key, fuse blows immediately. this is when i found/remembered the cut wires near the handle bars. these connections are not great, cut, wires twisted and taped. i took off the old dirty dry tape, changed to fuse and turned the key. it didn't blow. so i assumed these connections were shorting somehow.
so i hit the start button, just a tap no fuel tank on the bike yet. it seemed like it would of started so i'm assuming i have to redo these connections and ill be good. but then before i turned the key off the red light (temp?) turned on and then boom CDI box blows, smokes and is clearly done. oh and the fuse in solenoid did not blow this time
what happened? the wires were shorting and blowing the fuse and a separate cdi issue once it received power? or another issue causing all of it? any insight would be much appreciated. i may have the stock cdi still but if i put it in is it going to release the factory smoke as well? what can i check/test. is there something better i can do with the "mods" i did 20 years ago? or just make better connections and leave as is?
sorry for the long winded post Thanks in Advance.
