After 30 minutes of hard riding the quad went into a rev limiting mode. I replace the reverse limiting sensor and did an over ride button and it worked great. Now, I have a new problem. I ride hard for 30 minutes and a backfire occurs and the engine shuts of and will not restart. The nextday The quad will startand runs perfect until 30 minutes into the ride and the symptom reoccur. I am thinking an electronic problem, coil, stator, cdi. Anyone have an idea to put me on the right track to fix?
Check your gas cap vent. Air in, none out. You may be running out of gas as a vacuum forms in the tank. Loosen the cap and I bet it will restart.
