2004 660r Carb issue and frame/alignment.
228 Views 8 Replies 6 Participants Last post by  Supermike
4
Attached some pictures of the quad where i believe the frame is slightly bent/crooked.
as far as the carb. Took it out this weekend ran fine. Did notice that once started the second carb would occasionally dump gas for about 20 seconds then stop. Ran fine for 2-3 hours. Hit creek then slowly started to big down. Seemed flooded a bit after that.
Carb started dumping more. Would start up, pur then bog down.
Debating on doing a frame swap but would like to avoid that as much as possible. Would like to get alignment better any ideas where to start?
As far as the carb issue goes, what would you recommend. Clean and replace jets or get brand new carburetor?
Plant Sky Nature Tree Motor vehicle
Wheel Sky Cloud Plant Self-propelled artillery
Tire Bicycle tire Crankset Bicycle frame Motor vehicle
Tire Wheel Automotive tire Motor vehicle Tread
1 - 9 of 9 Posts
I imagine the floats are stuck in the carb. I couldn't imagine the frame being that tweaked with no other signs of damage.
Sent from my SM-G975U using Tapatalk
Reactions: 2
I would replace the float valves. The rubber on them gets old and hard. Also, replace the O rings on the tube that supplies fuel to the second carb. Mine was leaking there and it looked like it was coming out of the overflow hole until I looked really close. These are metric O rings, made for fuel. Not ones that you can get at your local hardware store.
Reactions: 1
Yeah i recently put the skid plate on that’s how i noticed something wasn’t right with the frame.
Wheels are definitely not aligned.
Almost seems like the raptor is doing a side crunch.
nothing looks wrong with the swing arms but maybe??
The left side looks off to me
Gonna be breaking down the carb soon to clean floats.
Word any recs on a kit or anything off Amazon or an atv site geared toward that carb should work?
I would get OEM parts. I have not had much luck with Amazon/E Bay aftermarket kits. They just don't last as long as the OEM Mikuni parts.
OEM Parts (rockymountainatvmc.com)
You want part number 29 for the float valve (Needle Valve), and #9 for the fuel tube O ring. Both are in stock.
Reactions: 1
You need a needle and seat for each carb, and that's why one is leaking.
I would place bets on the swingarm bearings and bushes been shot rather than the frame twisted
1 - 9 of 9 Posts
