I recently bought a 2004 yamaha Raptor 660 that didnt run. I was told it had electrical problems. Well I got it home and start working on it and realized that alot of the wiring was fried. I replaced the wiring harness, starter relay, starter, battery, and electric start/kill switch. I still can not get the raptor to start. I tried pulling it off my truck and I can get it to turn over but not start. Whenever I hit the start button I hear alot of clicking from under the seat I believe from the starter relay but every now and then it will turn over but I feel like it is turning over slow or weak. I think I may need another one way but I dont have any idea how to check if its good or bad. Any input would be greatly appreciated. Let me know if you have any other questions. I believe I covered everything. Thank you
how long has the gas been sitting in the unit? probably need to dump the old gas and get some fresh gas in there.
ok I will do that today or in the morning. How hard is it to check and see if the gas is passing throught the carburetor or if the are clogged up?
if its been sitting for a while you should take it off and clean it. do a search for on it and there is a walk through on how to remove. I have a 350 and it takes me 10 minutes to take it off.
Clean carbs properly, check all connections at the battery and check the starter.........
Use a set of jumper cables to a known good battery - does it turn over well now? If so your battery is weak. Else, it's connection or cable issue... and clean your carbs thoroughly and properly as Willy suggests - they are ALWAYS filthy when you get the bike used.
Download the manual from the 660 Maintenance Sticky section (at top) - wiring diagram is last page. There's not much to it, you can follow with a meter and make sure all is well.
