Hi guys, I just got a 2005 Raptor 660 and when I get to high speeds the front end shakes almost like a car does when it needs an alignment....any ideas what this could be and/or how much to fix?
Thanks
Git-R-Done
Welcome to the forum!!!! did you check and see if one of the rims are bent. that might cause it to shake.
camber off, alignment, dif air pressures, bad tire, bad wheel, bent spindle, loose wheel or spindle, bad tie rod, oh or could be a bad spindle bearing.
Hehe mine does to ....check ur motor mounts n make sure all ur bolts r tight
Make sure to check all FIVE mounts!
One or both of the front wheels are out of balance.................
