Long pedal to mechanical stop and quite bad response. Not able to lock on tarmac.
Tried to top up brake reservoir same fault.
Aren't these brake autoadjusting?
pads are approx 1/2 way done.
Any ideas?
Any ideas?
Bleed your brakes. If the fluid is over 2 years old then drain it and replace with fresh new fluid. make sure you bleed the system of all the air, you will need a friend to help with this. Bleed the banjo bolts on the master cylinder and the rear caliper also. Then pump the brakes and bleed the caliper last.
good luck
