:help:my 2006 raptor wont start it shows a 46 engine code anyone had this problem before
R ryanraptor · Registered Joined Feb 1, 2007 · 7 Posts Discussion Starter · #1 · Feb 1, 2007 Only show this user :help:my 2006 raptor wont start it shows a 46 engine code anyone had this problem before
Hippy · Registered Joined Apr 3, 2006 · 649 Posts #2 · Feb 2, 2007 Only show this user code 46 is Vehicle system power supply Power supply to the fuel injection system is not normal I would start by checking all the wires loss connections or broken good luck
Hippy · Registered Joined Apr 3, 2006 · 649 Posts #3 · Feb 2, 2007 Only show this user found this, says it could be a Malfunction in the charging system. see how much volts the battery is putting out if its low try a jump just to see if it will start and then take it from there .
