1 - 10 of 10 Posts
We was riding today. I pulled up shut it off. The when to put it into neutrel to start it and it wouldn't go into neutral first or reverse. But it will shift up third fourth 5th and back to second. Any ideas?
It shifts up and down fine just wont go down past 2nd it rides fine but when I try to shift it down its like nothings there just wont shift down from second.
If you cant use first, or reverse, your tranny has issues. Maybe, if you're lucky, those 2 gears are only stripped, and need replacing. Good luck.
Research the Raptor 350 common problems, and 2001-03 I believe, Raptor 660's. Raptor 350's tranny tend to go out often, and I believe the issues with the 660's were 1st or 2cnd gear going out.
Sounds like it could be bent shift forks to though. Does it go into 1st and just not move or will it not go below 2nd at all?
Yeah it just wont go down from 2nd. It goes up and down from 2 to 5th just fine.
Its a 2006 raptor 700
What's the best place to buy the crank case?
1 - 10 of 10 Posts
