Need some help with turbo raptor running way to rich . Have a 734 stroker Ross 7.5 piston kibblewhite valves running mcxusa
Inter cooled turbo kit but makes no power and runs so rich it’s untrue
Has a beta gen3.5 controller with second injector and after 18 months of building and
Miserable can’t ride it without melting turn signals and stinking of fuel help !!!
Are you trying to datalog when riding and tune the air/fuel from that info?
If not, it Needs to be dyno tuned, which would be better anyway.
You're not going to be able to just push a button a couple times on a piggyback fuel controller and tune a turbo.
Fortunately it's rich.
Discussion Starter #3
No I only have a wideband on the bars and even with the gen 3.5 on minimum I am still 10-1 afr
Have you tried running on one, factory, injector? It's possible you need a different controller.
Regardless, you Need it on a dyno.
Turbos are picky, and you Need an experienced motorcycle turbo tuner before you end up with a boat anchor.
