Working on a friends ltz 250, cleaned the carb and tank, but the fuel petcock does not have an off, it has prime, on, and reserve. I can only get it to run with the fuel petcock on prime with the prime hose not connected to the carb only the main fuel hose connected. If I connect the little prime hose the motor stops. When it is running like I explain, fuel comes out of the prime hose while running. I will posted some pictures tonight to help if needed. I hope some one understands how I explained this, lol
the "PRI" position is for starting in cold weather when using the choke
the "ON" position serves more than one purpose, and really the only one used
- leave it in this position when the quad is not running or when it is running, in this position the pet-cock only supplies fuel from the tank to the carb when the engine is running
the "RES" position is only used when you run out of fuel in the "ON" position
Thanks for the reply, I used a yamaha warrior fuel petcock, and it runs like a champ now.
Hey, I am moving to Panama City, FL. in January 2013. Are there alot of good places to ride out there? I mostly trail ride on my LTZ400, but I also have a LT250R.
I have been told a place called mossy head, and boggs and boulders.
