Hey, guys I need assistance on installing a Tusk tether kill switch to my 2009 Raptor 90. Instructions says; ATV with Battery Ignitions systems, wire from the kill switch goes to the pulse trigger lead from the stator and other wire to ground bear metal. Do you guys know where the pulse trigger lead located and what color of wire. Thanks any help would be appreciated!
Just get a NC (normally closed) and install it in line with the kill switch.
Alright guys I did my home work. I found the wire where to tap into the pulse trigger lead from the stator. It’s a white/red stripe wire coming out from the stator right side crankcase of the atv leading to the Cdi box next to the battery. The voltage on that wire is any where from 1.9V AC - 2.3V AC. My tether kill switch is now wired properly according to the instructions and working properly. I hope this helps you all.
141084
141085
