guys Ive just red on the Yamaha site.... for the 2011 and 2012 Raptor that they have a built in rpm gauge in the cluster?
I have a 2011 and I was not aware.... how the hell do you get it to display?
Here it is. I dont see anywhere about having a RPM gauge. ???
http://www.yamaha-motor.com/sport/products/modelfeatures/439/0/features.aspx
Key Features:
•A 686cc Yamaha fuel-injected engine makes this the most powerful Yamaha sport ATV ever, with big torque right off idle, transitioning into a fat mid-range and monstrous top end.
•The Raptor 700R comes standard with a digital meter. Riders have plenty of information available at a glance, including speedometer, dual trip meters, odometer, clock and engine warning indicators, plus neutral and reverse indicators.
•Sport-tuned piggyback shocks provide long stroke for excellent sport-riding comfort, and are fully adjustable with convenient adjustment knobs to fine-tune the ride.
•Hybrid steel and aluminum frame with a Controlled-Fill aluminum subframe and cast aluminum swingarm combine to produce a super-strong structure and the lightest ATV in its class.
•Aggressive styling reflects Raptor 700R’s intent, and YFZ-inspired handling means it walks the walk, too.
•Long-travel suspension—9.1 inches front, 10.1 rear—a cush seat and excellent ergonomics make the Raptor 700R comfortable to ride hard all day long.
Engine:
•Forged lightweight piston, connecting rod and crankshaft in the 686cc engine are light and strong, for a hard-hitting, quick-revving powerplant that revs all the way to 9000 rpm. Dual counterbalancers keep it smooth.
•Yamaha Fuel Injection (YFI) means consistently excellent engine performance in a wide range of conditions, elevations and temperatures.
•Competition-spec dry-sump lubrication system boosts usable horsepower and keeps overall engine size more compact.
•Digital TCI w/16-bit electronic control unit controls fuel injection and ignition systems for consistent performance and fantastic throttle response.
•Reliable pushbutton electric start in any gear adds extra convenience.
•Race-bred five-speed transmission with reverse, along with Raptor 700R’s monstrous powerband, means there’s a choice of gears in just about all situations.
•YZ-spec ratchet shifter ensures smooth, resistance-free shifting under power. Heavy-duty clutch features extra-sturdy basket and plates designed to harness the Raptor 700R’s power.
•Easy-to-reach oil filter and tool-free air filter provide added convenience.
Chassis/Suspension:
•State-of-the-art chassis combines a steel front section with an aluminum rear section and detachable subframe to create a super-strong structure.
•Compact, CAD-designed chassis creates the ideal wheelbase for light, quick, super-accurate steering.
•Piggyback shocks provide excellent sport-riding comfort, with high- and low-speed compression adjustability, rebound and preload adjustability, and 9.1-inch travel.
•YZ-style piggyback rear shock gives 10.1-inch wheel travel with high- and low-speed compression adjustability for maximum sport versatility, along with preload and rebound adjustment.
•Front brake master cylinder features an adjustable lever for increased comfort and feel.
•Twin aluminum-piston front disc brakes deliver tremendous stopping power. Discs are drilled, which helps reduce unsprung weight for excellent suspension compliance.
•Cast aluminum swingarm carries an eccentric quick-adjust drive chain mechanism that takes most of the work out of that task.
•Handlebar-mounted flip-type parking brake lever and rear brake caliper adjust automatically.
•High-performance 21x7-10 front and 20x10-9 rear Dunlop® radials with a specially designed tread pattern deliver superb, class-leading traction for razor-sharp handling in a variety of terrain and conditions.
•Lightweight aluminum wheels help enhance suspension performance by reducing unsprung weight.
•Race-inspired 45mm serrated footpegs provide excellent boot traction.
•Controlled-fill aluminum subframe is light and strong. So is the composite front grab bar.
Additional Features:
•Yamaha introduces an Industry First! Starting with the 2012 model year, every Sport ATV model will feature a white color version that can be customized with 1 of 11 graphic choices. After purchasing their ATV, customers order their customizable graphics from ONE® Industries.
•Raptor 700R features a digital meter with speedometer, dual trip meters, odometer, clock, warning indicators for coolant and low fuel, plus neutral and reverse indicators.
•Inner rolled wheels reduce weight while maintaining strength.
•Long, YZ-style seat allows maximum rider comfort and movement with superb sport-riding ergonomics.
•Multireflector 30-watt Krypton headlights set back in the front cowl add the perfect no-compromises sporting accent, and an LED taillight provides great visibility.
•Large-capacity, 2.9-gallon fuel tank and Yamaha Fuel Injection (YFI) mean more time on the trail between fill-ups.
•Thumb throttle lever has a smooth shape for a feel riders will appreciate, with less fatigue at the end of the day.
•Styling is sharp and aggressive.
