1 - 2 of 2 Posts
Hello
My 2012 raptor 700 had an accident
Since then, the upper side of both front tires is tilted in while the lower part is tilted out.
Changed all 4 controls arms but still not fixing the problem
My tires got worn quickly at the inner side
What could be wrong
I don't have a 700 to look at, but I believe that alignment is by design. You can put a square against each wheel and see if they are the same. If they are much different, you may have a bent frame. Have you measured the toe-in?
You can buy aftermarket a-arms that are adjustable for camber and caster.
I suspect you are riding on the street, but those aren't street tires and will wear.
Reactions: Sixpack577
1 - 2 of 2 Posts
