In need of Help I have a raptor 700 r ran great until I parked it for the winter I pulled it out it was real hard for it to turn over I jumped it with a jump pack started right up ran for about 10 mins and shut off went to start it again it will turn over slow and won’t start since then iv put a new battery in it a new starter and starter relay still didn’t help it turns over slow for a min then the relay will just click iv checked the decomp pin in the can it’s working how it should and valve clearance is exactly where it needs to be I’m lost as to what to do next only after market parts are a pc3 programmer and a duel looney tuned exhaust if anyone could help or has a suggestion That would be great thanks
New batteries arent always good just because theyre new. Test it with your voltmeter. Then test it with the voltmeter while its cranking and see if it drops low
Reactions: morphrider
