1 - 20 of 1128 Posts
Because we are behind the times thanks 4stroker4life
Sent from my iPhone using Tapatalk Pro
Discussion Starter #2
I guess i should have made it in the right place
No worries! Morph will move it for us when he sees it
I've been waiting for this one.
Happy new year everyone. Many safe trips, tons of great mods and no mechanical failures.
Man I remember when segkast was the one to start these.
Sent from my SM-G930V using Tapatalk
Discussion Starter #6
Sounds good to me. Hope the same for everyone else as well
Discussion Starter #7
Well fellas its a little frigid outside at the moment. Not sure if im the correct state or not. My shorts say FL but my hypothermia says Antarctia.
It was -5 yesterday in Saint Louis and today it's 21 and very thankful. Lol
I can remember -30 when I lived in Chicago. Out west it doesn't go much below freezing where I live, and if I want snow the mountains are close.
Discussion Starter #10
Yeah thats a little too cold for me now days.
Discussion Starter #11
Yep i think i would be as well. I guess at negative 5 i would have to wear something more than cargo shorts.
Who's secretly checking out the new KTM 300 EXC-F 2-Cycle with fuel injection that's street legal in 49 states?
Not me!
Discussion Starter #17
So i think i need a new rear axle, whats everyone’s thoughts, stay stock(cheaper and i havent had a problem with it yet) or go aftermarket for a few dollars more?
How hard do you ride or how high do you jump? Will you have extended A-Arms and need a wider axle to match? Check ebay for AM axles from a part out.
A new factory axle is $238 on Partzilla. A Tusk on ebay is under $200. A used factory axle is $125. Do you want to put brand new sprocket and brake hubs on worn splines??
Discussion Starter #20
I havent bent a stock Axel yet. And I’m not evil Knievel and jump buses. I do run some MX and I’m getting better at it so my jumps are getting higher in further. I have extended aarms, i also have extended/bigger hubs (not spacers)
