Oh. What's wrong with the stock reverse?
Once you use a Dr. D ,you do not want to go back. Your hands never leave the bar. Just flick it with your thumb and go.Oh. What's wrong with the stock reverse?
Oh.... I could see how that would be very nice..Once you use a Dr. D ,you do not want to go back. Your hands never leave the bar. Just flick it with your thumb and go.
Priceless.....
Yep, this^Once you use a Dr. D ,you do not want to go back. Your hands never leave the bar. Just flick it with your thumb and go.
Priceless.....
Nothing, I just think there are better ways to engage reverse than taking your hand off the bars to turn a knob.Oh. What's wrong with the stock reverse?
Put the Ricochet swingarm skidplate on, measured it...and no thank you.
I emailed for a return.
It also has a ridicoulously excessive clearance between the sprocket and rotor, and sits only a quarter inch higher than the gytr.
The chain guide has exposed lock nuts underneathe to the inside, and there is less protection at the rear given the shape.
Is it a good skidplate?
I'm sure it does the job.
But, as far as I'm concerned, the discontinued PRM swingarm skidplate is the only correctly made skidplate out there.
The gytr and ricochet are not as good because of their design.
Yes, wet clutch Amsoil.which skid plate you going with now?
also on a side note. i noticed the oil you are using is not the amsoil for atv. is it jaso certified for wet clutch the one your using?
I been looking at the kemimoto as well. Price is cheaper than the rest too.Yes, wet clutch Amsoil.
Gytr swingarm skidplate going back on for now, or maybe stock plastic.
I will continue to search for a used PRM.
May try a new KemiMoto.
Ive been wanting to do the Vapor for a couple years and they discontinued their old bar clamp mount, i cant find the one you have on their site do you have a link?A Trail-Tech Vapor went on before starting so the hours and miles would be correct from the beginning. View attachment 139495
I'll look, but I got it on ebayIve been wanting to do the Vapor for a couple years and they discontinued their old bar clamp mount, i cant find the one you have on their site do you have a link?
Found it, thanks for the info...I'll look, but I got it on ebay
