1 - 20 of 22 Posts
I just bought a 2005 Raptor 350 with no motor. Can I install a 660 motor in its place? I am not familiar with yamaha machines so I dont know where to began to look. Thanks
If you have all the "know-how" and tools, then hell yea its possibly. I am not sure if the engine will actually fit with out cutting the engine mounts. I know over at yfm, some guy wanted to put a YFZ 450 engine in the 350, and he would have just needed to make new engine mounts.
Hey, I know.
buy my 2005 660
awsume shape
just up graded to the 700
$4500 or best offer
Good luck, the raptor motor is tall compared to the 350 engine, get a 450, it is smaller and will kick any raptors ass.
the hell if it will :bs: . most heavily modded 450's cant even come close to touching my 70 + horse raptor. lol and im not even close to being done. adding 30 more horse by spring.
Maybe he meant 350 Raptors?
This is all too confusing, I wish everyone would just call the 350 what it is... A warrior.
First he is talking about putting a 660 engine into a Raptor 350 (warrior) frame ( less confusing) and I suggest he put a 450 engine which is smaller, lighter, and a faster engine by all means, now someone is b.s.ing about his 100hp raptor to be. I wonder what kind of Raptor engine can put out 100 hp, 3 times the stock HP rating, anything is possible but why put such an engine into a (warrior) frame. Again I say good luck, some people have wild imaginations, others have wild imaginations and can make it happen.
And I was talking about the 350 Raptor, (warrior) I wouldn't mind seeing a 450 engine in a Raptor (warrior) frame. It would turn a few heads.
first you said a 450 will kick any raptors ass.
second my 700 is 108 big bore 8 mil stroker with 14.1 piston that makes an 843 cc will make 100 horse there buddy. if you dont believe me just ask rocket factory. so dont say that a raptor cant make 3 times the power of stock. im already twice as powerful as stock now.
Well My mistake when I said any Raptor, ( warrior) Raptor 350 is what I meant and good luck on the 100 hp Raptor, I won't bother asking rocket factory about the 100hp engine, I am sure you got it mistaken with one of there rockets that NASA uses.
ok back on topic why not just buy a 350 off the bay they are cheap low maint. and put out a good amount of power with a little work.
"just ask rocket factory" :lol:
i dont believe there is any raptor, 660 or 700 to date that has even broken into the 90's without nitrous/turbo.....
low 80's is all ive ever seen
oh and there is a warrior on PS that has an XR650 motor in it. pretty sick. i think the look of the warrior would provide the ultimate sleeper. it would be sweet to put a crf450r motor in one
I've read of alcohol bikes with nitrous making 100hp, and that's about it.
~Brian
:bs: :bs: :bs: :bs: :bs:
It would be a lot easier droping a 450 motor end.. You will have to be able to get someone to fabricate some mounts for you and get everything aligned correctly.
You can find a fairly tune/built 450 motor anywhere between 1500-2500.00 on YFZcentral
Good luck on your build
Maybe I should ask Rocket Factory, but I know what there answer is already, just use common sense, this is not an F1 engine we have here.
not trying to argue, this cylinder just came out and they easily broke the 90's on them. jason from rocket factory will tell ya. wait till we figure them out and get more familiar on them. 100 should be pretty easy to reach. a 450 motor on a 350 would be a interesting build.
a stock raptor bore is a 102 mil.
the big bores that have been out a while are 105 and a 105.5.
this new cylinder is a 108 mil.
on top of that is a cp 12.5 stroker piston with the added 8 mil crank it makes 14.1 compression. yes its NA. and hittin low to mid 90's already.
combined with a 8 mil stroker crankshaft and it turns a 700 which is a 686. into a true 843 cc. the first cylinder gets here just before christmas. so i should have mine by beggining january. they have already been tested on many bikes.
1 - 20 of 22 Posts
