1 - 13 of 13 Posts
I have a 2005 350, bought it off a co-worker, it has problems starting, I bought a new starter solenoid and a new battery and it won’t even do anything. Any advice would be greatly appreciated.
do the lights turn on? if not its the fuse it could be the cdi box or even the starter button most yamaha warrior/raptor 350's get a short in starter button
Be sure it's in neutral.
Key on.
Jump the solenoid.
Reactions: Sixpack577
If it will sometimes try to start and sometimes not i suspect a loose or corroded ground wire
Im having the same issue with my freshly rebuilt one got a test ride out of it an that was it today it started smoking at the battery 06 raptor 350 im going to check my grounds tomorrow or I should say replace them too. Everything is new except the wiring and plastic rebuilt myself an trying to get it figured out but lost with the wiring stuff sorry didnt mean to chime on your forum really need some help on this
Discussion Starter #13
It’s all good, I’m not big into wiring so I took mine to a shop because I didn’t want to make any mistakes in the wiring
1 - 13 of 13 Posts
