i need help with my 350raptor its running really weak?,
  • k
    Votes: 0 0.0%
  • k
    Votes: 0 0.0%
has trouble starting, backfires..... :'( i was able to beat some banshee's no i can run faster than my atv just kidding. maybe i need to adjust the valves or piston
ive tried the plug i got the denso iridium, but i never adjusted the valvas since i got it almost two years it also leaks oil from the top close to the header bolts
I would check your valve clearance. Also it's a simple allen and a new o ring will fix that leaking rocker arm cover.
Mike
