1 - 11 of 11 Posts
Have a 2019 700r with pro design foam intake pcfc and big gun slip on stock header pipe. My question is would a +3mm tb work good with this set up with out changing the pistols or values and will I lose low range power with the +3mmtb any info would be great ty.
The upgraded TB wouldn't do anything if you don't have some head work.
Sent from my Pixel 4 XL using Tapatalk
Not even close to accurate.
You wouldn’t really see any losses, but I doubt youde see much benefit through the stock exhaust.
The bored throttle body is worth up to 3-4hp above a standard big 3 setup. If paired with a hotcam 3 it’s usually closer to 8-9hp gain. This is common to do both at the same time, especially on 2015+ bikes. They have enough compression that any bottom end loss is minimal.
you would need a new fuel map.
Reactions: Yamil Xiscatti
What you mean
I replied to palvarez that what he said was not even close to accurate. Because it is a 100% false statement. The +3 throttle body’s absolutely help make power on a stock head.
The stock cam peaks out where the +3TB starts making more power. You need more cam or a larger engine to reap the benefits of the additional airflow. The stock TB matches up good to the stock low rpm cam.
This thread really has me thinkin...I really gotta pick one of these up now that I’m back to work. I mean for $200 I think I could see huge gains with my +2 head.
Yeah, you’re way past needing one. I run a 54 on my +2.
1 - 11 of 11 Posts
