1 - 20 of 25 Posts
What parts would be an upgrade for the 660 off the yfz 450?
anything else? i have 09 yfz 450 front shocks and im looking at a couple pair of calipers. the stem is shorter isnt it?
What about the rear master? does it make a difference?
I did the front calipers and shocks. Since then I have upgraded my shocks but the calipers are a huge ++
how much of a difference does the stem make? and id just have to get risers to clear the tank.
well its a lot easier to find an aftermarket stem for a yfz than it is for a raptor 660... just find an aftermarket +1 or 2. go to yfzcentral.com or whatever it is
oh ok. thanks for ur help tommy.
do i need just the caliper and itll bolt right on the 660 spindle or do i need the whole 450 spindle as well?
They bolt right up, the only thing ya gota do is trimm the metal or plastic guard to fit the calipers....
sweet! is there a write up anywhere? like a how-to? if not i may write one up and take pics
The 04-09 yfz 450 brake parts swap, not sure about the 09+ yfzr or yfzx.
The 09yfzr shocks are too long for standard travel a-arms on the 660.
Discussion Starter · #18 ·
so does that mean i need to get extended a-arms or the stocks will work with the 450 shock mod?
I don't know what yfz you're pulling these off. If it's a yfzr you need to buy aftermarket long travel a-arms. if it's a yfz or yfzx the "mod" for clearancing the a-arms and upper shock mounts will work.
I think it was a yfz. They came with the bike
1 - 20 of 25 Posts
